so the box is gonna need to be 5.71 ft3
so what what would length, width and height need to be
i have 7% in my math class, but i know how to figure this out, i just cant remember how...
L X W X H = 5.71
The problem is indeterminate - meaning it does not have a precise answer.
You'll have to decide on two dimensions, then solve for the third. For example, say you decide you want it 18" (or 1.5 feet) wide and where you want to put it, you can go 2 feet deep, you would have:
2 X 1.5 X H = 5.71 or 3(H)=5.71 or H=1.903 feet.
Considering the thickness of the panels and interior bracing, you might go with 2.2 feet for the height if you want to retain 5.71 cu ft as your interior volume. This is, of course a rough estimate, but it seems reasonably accurate for this project.
You would do yourself a favor to build a prototype box out of corrugated cardboard. You can build it at half scale and use duct tape, but pay attention to which edges are going inside of which sides. Stuff like that can trip you up!
