First off, don't be so serious. Laugh a little.
Second, a little primer on amp power vs. speaker sensitivity. Get the sensitivity figure for your speakers. That is critical to this.
In the meantime, I'll assume (and use) a figure of 87 db/meter but you should be able to iterpolate whatever it is that you need to know.
An amplifer with 100 watts into an 87 db speaker will be able to produce a certain loudness.
To increase that loudness by a BARELY AUDIABLE 3 decibles will require twice that power, or 200 watts.
To increase the loudness another 3 decibles requires twice that power, or 400 watts.
So, to gain a mere 6 decibles over your initial 100 watt amp, you need 400 watts.
Let's look at this another way, starting with 100 watts into those 87 db speakers.
If those had a sensitivity of 90 db/meter, or 3 db more efficient, to obtain that same loudness you would only need 50 watts.
In that same vein, if they were 93 db speakers, that same loudness would be reached with only 25 watts.
So, even if you used a 200 watt amp, your loudness would not increase all that much. Also, that 100 watt figure is only called upon for peaks, and even then for only a short time.
You might want to seriously consider either lowering your listening level expectations or looking into more efficient speakers. Some speakers simply aren't made to pump out the noise, particularly in a large room.
