crosiev, I am running a D-Sonic 2000-5, powering my Paradigm Sig S4's, C3 & ADP-590's, JL Fathom F112.
Specs
3 X 525W / 8Ω 3 front channels
2 X 250W / 8Ω 2 rear channels
18”W x 7”H x 13”D
Weight: 45.2 lbs
Price: $2590
Those power ratings double at 4ohms...
I am extremely happy with this amp, extremely !!!
Although they are not the most beautiful looking amps, the build quality is amazing, yet simple and understated clean lines, which reminds me of some old Heath Kit type DIY buildable products, which I always had some affinity towards. Extremely heavy duty construction and top notch speaker connections as well as balanced inputs or RCA. I knew I wouldn't need to win any awards for the best looking stuff, that is hidden in my basement.
This is no white van product, and contains the highest quality 1000ASP B&O modules, stated to have the best SQ of all the prior modules. I can attest to their credentials. Jeff Rolands stuff sells for over $4K for dual monoblocks of the same exact 1000ASP modules...
I think these are a far better deal, for the same thing.
The D-Sonic really pulled this system all together for me, the impact, the clarity, low noise floor has left me wanting for nothing more... Ordering from Dennis was seamless and communication was great. Let me also add that this amp is probably way more then overkill for anyone, but it was a choice between that or the Parasound Halo A51. IMO either would have been a fine choice and I decided to try something new, and I don't regret my decision one bit, except for the drain on my wallet...
Here are some pics of my setup, now that I have my furniture and I finished painting, just need some more decorations, but I think it has come together quite nicely. The equipment is all in the basement just below the room, with communication and coordination handled by my Pronto TSU9600 over WiFi.
I hope this helps...
