i1Display LT good color calibration for beginner?
F
FuzzyReets
Hi folks. I decided I would like to maybe get a colorimeter to adjust my plasma with (Samsung PN58C550). I am a total newb to this and this is the product that seems to be the right fit for someone in my shoes. Will I be able to calibrate my plasma color with this product? Just want to make sure. Also, is the upgrade to the i1Display 2 worth it? Thanks.
F
FuzzyReets
Well I got the i1display lt today and the DVE disc. My question is whether or not the thing has to be completely flat or not. The manual that came with it says to not push on the lcd screen so does that mean it does not have to be flat or the suction cups have to be connected and make it flat? Not sure what the proper procedure is. Don't want to damage my TV but want to get a good reading. Thanks.
F
FuzzyReets
Also. Is there some kind of base setting I should start off with with my backlight or other settings or should I just use what I'm currently using for settings and go from there?
F
FuzzyReets
Is the GRETAGMACBETH EYE-ONE DISPLAY 2 the same as the X Rite i1Display 2?
F
FuzzyReets
I spent pretty much the whole day sunday calibrating 2 TVs in my house and it was pretty enjoyable overall. I was pretty meticulous about my main 58" set so I spent a lot of time on it. Overall I think it looks much better and I like the skin tones a lot more but I will say I think certain things that should be white have a certain greenish/blue tint to them that I'm not really into but I don't want to start changing the wrong things. According to the diagrams, I am pretty close to dead on but I'd like to get rid of this greenish/blue thing going on without totally blowing my settings. Anyone have advice on how to go about that? Thanks.
F
FuzzyReets
Don't know if anyone is still following with this thread but I think I'm going about give up on this calibration stuff. I spent the last 2 days trying to get my plasma looking good and it looks like crap even though my numbers are good. This leads me to believe that I have some setting wrong. The other 2 LCDs I did look great but my main TV, a plasma, looks dark and crappy. The one thing that is different setting wise is that I'm using the plasma profile here and not the LCD even though the walkthrough indicates if you are using the Eye One to use the plasma profile for plasma. Seems to make sense but it looks BAD. I set my old settings back which were on the standard profile and my new calibrations which are on my movie setting and flipped back and forth. The calibrated settings in the movie mode look terrible. I'm still not totally happy with the non calibrated old standard settings I had and I believe it can be better because the 2 LCDs I did do look much better but there is something wrong here with whatever I'm doing with the plasma. End result looks dark in all aspects. Any help would be appreciated. Thanks.
davidjschenk
Hi FuzzyReets,
Exactly the same. The LT is also the exact same hardware but with slightly different software (that no one ever uses because the free HCFR software is FAR superior). Install HCFR, burn yourself a copy of the AVS-HD disc (you burn it to a DVD, but it burns in 1080p BD format and works great), and you'll be all set to go.
Yours,
David
davidjschenk
Hm. Can you say anything more about what looks wrong on your post-calibration plasma? Aslo, what make and model is it? If it looks too dark, my guess is you've got brightness, perhaps contrast, and perhaps gamma improperly set. How did you fix brightness and contrast? This is generally not done with the meter and software, but visually with the basic patterns available on the AVS-HD disc. You want brightness to be set so the dark bar numbered 16 just barely disappears into the background but the bar numbered 17 is definitely but only just barely visible (in a light-controlled room, mind you). You want contrast to be set so the TV displays as many bright gray bars as possible above 235. The better ones easily go all the way up to 252 or even 254. Also, if the bars at the bright end start turning at all pink, you've pushed contrast too high and should lower it until the pink disappears. Have you tied that yet?
Don't give up, FuzzyReets; I've been doing fairly committed amateur calibration work since 2007 and I'll be more than happy to help you work through whatever problems you're having right now.
Yours,
David
