I Switched to a Passive Preamp and a Crown Power Amp
  • Thread starter Thread starter Mark of Cenla
Mark of Cenla
412
0
28
69
nothern Louisiana
I was using a Sherwood receiver and switched to a Nobsound NS-05P passive preamp and a Crown X-1000 power amp. The speakers are Boston Acoustics A26 bookshelf speakers. The clarity is amazing! I was using a subwoofer but am now just using the Bostons. I have no tone controls and do not need any. I cannot get over how good this sounds.
Is anyone else using a passive preamp, which is really just a volume control?
Peace and goodwill.
I have a NEC CD player which has output with a volume control that I often use connected directly to an Adcom GFA 555 II when testing speakers. I also connect my laptop directly to amplifiers for testing purposes which includes playing music.
As long as you are using line level sources with some form of gain/level control, that's all you need.
Yep that's sort of the straight wire approach. As long as you don't need anything but (I'd find it too limiting personally).
Well I used two RCA splitters to send one signal to the Crown X-1000 and the other to my SONY subwoofer. To me it now sounds amazing. Peace and goodwill.
