Ok, so I have built the Kappa simple build and am hooked on DIY home audio. I hate to bother everyone but I have some questions.
To begin with here is my setup.
Pioneer VSX-504s 5.1 (150 watts RMS) (1997 model)
Bash 300 plate amp
Infinity Kappa Perfect 12 DVQ
DIY Mark III MTM speakers
1. My sub sounds great with music. It blends nicely and is very accurate. Here is my situation. If I turn the music up to a level that makes the sub actually start to move, my mains start maxing out. If I listen to the music at a comfortable level the sub is doing nothing. (sounds good but no real impact)
So, in order to get the sub more volume what do I need to do? Cap the mains so they don't blow out. Cap the sub so it doesn't recieve any high frequency. And boost the low end to get the bass I desire...correct?
2. If I purchased the Behringer 2500 amp and the DCX2496 would this allow me to address these situations?
3. My sub is good at getting very deep but I don't get the punch in the chest effect from it. Is this due to the lack of watts that all of you had warned me about, or is it simply not what this sub was desingned to provide?
4. My sub is in a fairly large room. 22x14 with openings to the downstairs as well as the dinning room. Could this be the cause of the lack of punch?
5. Would building two subs provide better oomph? That is an obvoius question but would they then provide the palpable bass I am looking for? (your opinion)
6. I have my sub connected to the LFE sub connection on my reciever with a 50' RCA cable of low quality. Can there be NOTICABLE signal loss in a long length of RCA cable? Could this be a cause of my lack of volume from the sub?
I will end here as I am sure that this is plenty. Thank you all for all of your help.
If everything is balanced for music you should be fine. You should not be aware of subs. When deep bass is called for it should come out of nowhere. Good systems don't advertise their bass. However when all hell breaks loose in a movie, it should just startle the hell out of everyone, especially those that have never experienced anything like it before.
I keep pointing out that as you read these forums you would think all the audio energy is below 80 Hz. In point of fact there is very little energy below 80 Hz, except during sound effects. I think these subs talked about on the forums are over powered. I use less power below 80 Hz than is talked about on these forums, but significantly more above 100 Hz than most other members.
The major portion of the power is required between 100 and 1000 Hz.
Since you are into DIY, you should consider building mains with good units having powerful motor systems, such as the offerings in the SEAS Exel range, Scanspeak, Morel and of course Dynaudio, though sadly these latter drivers are no longer on the DIY market.
