help hooking up xbox 360 and surround sound
Adam Audioholic Jedi Sep 15, 2007 #2 Hey there, bDc_G_O_D. Welcome to the forum! I think that we'll need some more info from you in order to help. What are you hooking your xbox 360 into? A receiver? If so, which one?
AcuDefTechGuy Audioholic Jedi Sep 15, 2007 #3 What else do you have besides the xbox?? Receiver? 5.1 or 7.1? Speakers? What kind of TV? You connect the HDMI from the xbox to the receiver then HDMI output of the receiver to the TV.
mtrycrafts Seriously, I have no life. Sep 15, 2007 #4 bDc_G_O_D said: help hooking up xbox 360 and surround sound Click to expand... Welcome. Besides more info as posted above, your manual should have a wealth of info. When you get stuck afterwards, then specifics will go a long way.
GlocksRock Audioholic Spartan Sep 15, 2007 #5 If you don't have HDMI on your 360 or receiver, then you will have to use an optical digital cable to connect your 360 to your receiver, that is the only way to get true surround sound out of the 360.
