I need help identifying what cable this is!
hallowee1234
Hello, I was hoping if anybody could tell me what these audio connectors are. I am new, and I need help to determine what this connector is and if it is common.
ryanosaur
ryanosaur
Which are you talking about?
The "knobs" are Binding Posts. You also have RCA and Spring Clips there.
If it is the Binding Posts you are unfamiliar with, you can run bare wire through the side by unscrewing them and tightening them back on the wire... You may be able to do the same with Spade connectors. The hole in the middle will accept Banana Plugs.
hallowee1234
Thank you, I didn’t know that they were binding posts.
F
fmw
Unscrew the plastic knobs and a hole will be revealed that goes through the post. Insert your wire through the hole and tighten. I normally tin the wires with solder prior to inserting them.
