I need amplifier that can output bi-amp
U
uaeproz
Hi Experts,
I'm looking for a list of amplifiers that can output bi-amp to power my front towers. The room size is not determined yet cause I will be moving to a bigger space in couple of months so I will leave that out.
I want a list that can work perfectly and match my front towers and works with my receiver - Yamaha A/V Receiver RX-A3030
Here are few specs of my receiver and my Towers:
Receiver: Yamaha RX-A3030
Channel: 9.2
Rated Output Power (1kHz, 2ch driven): 165 W (8 ohms, 0.9% THD)
Rated Output Power (20Hz-20kHz, 2ch driven): 150 W (8 ohms, 0.06% THD)
Dynamic Power per Channel (8/6/4/2 ohms): 175 / 220 / 295 / 410 W
CINEMA DSP: Yes (HD3)
DSP Programs: 23
Dialog Level Adjustment: Yes
Virtual Presence Speaker: Yes (includes virtual rear)
Dialogue Lift: Yes (no presence speakers required)
SILENT CINEMA / Virtual CINEMA DSP: Yes
Dolby TrueHD: Yes
Dolby Digital Plus: Yes
Dolby Pro Logic IIx: Yes
DTS-HD Master Audio: Yes
Pure Direct: Yes (with video on mode)
Compressed Music Enhancer: Yes (high-resolution)
High-resolution Music Enhancer: Yes
Adaptive DRC (Dynamic Range Control): Yes
A.R.T. Wedge: Yes
Bi-amp capability: Yes
Audio Delay: Yes (0-500 ms)
192kHz/24-bit DACs for all channels: Yes (ESS Technology ES9016 SABRE32™ Ultra DAC + ESS Technology ES9006 SABRE™ Premier Audio DAC)
MHL Support: Yes
Digital Audio Input/Output: Optical 4 (1 front) / 1
Digital Audio Input/Output: Coaxial 3 / 0
Analog Audio Input/Output: 10 (1 front) / 1
Phono Input: Yes
Multi-Channel Input: 8-ch
Preout: 11.2-ch
Here is a link to my Receiver specs: RX-A3030 - AVENTAGE - Audio & Visual - Products - Yamaha United States
Front Tower Speakers: Yamaha Soavo-1
Type: 3-Way bass-reflex floor-standing
Woofers: Dual 6-1/2" (16cm) Advanced PMD Cone
MidRange Driver: 5" (13cm) Advanced PMD Cone
Tweeters: 1" (3cm) aluminum dome
DC-Diaphragm: Yes
Magnetic Shielding: Yes
Twin Bass Reflex Ports: Single
Gold-Plated Brass Extruded Terminals: Yes
Frequency Response: 35 Hz - 50 kHz
Sensitivity: 89 dB/2.83 V/1 m
Input Power (Maximum / Nominal): 200W / 50W
Crossover Frequencies: 500 Hz / 5 kHz
Impedance: 6 Ohms
Here is a link to my tower specs: Soavo 1 - Soavo - Home Speaker Systems - Speakers - Audio & Visual - Products - Yamaha United States
I just want to know a list of amplifiers that can output bi-amp and will match the speakers and receiver.
Cheers
Abdulla
agarwalro
agarwalro
That would be a pretty long list since most receivers in the mid range and up will allow this.
The Yamaha 3030 is a solid receiver for the speakers. Anthem, Denon and Marantz, are a few other manufacturers that will have the bi-amp feature in receivers costing the same as the 3030.
slipperybidness
slipperybidness
First off, bi-amping in a non-active crossover design isn't gonna gain anything, it will be a waste of time and wire.
2nd, that Yammy that you have is already bi-amp capable.
crossedover
crossedover
Uif you feel you need more power just buy amp and run it out of the preouts. How ever your gonna need a 350wpc amp to notice a difference in power. ;) passive biamping as mentioned isn't gonna get any results with your setup.
U
uaeproz
I've got a reply from other forum that says +3db is what I'm gonna gain?? +3db is not much of a difference and not worth the spend.
The purpose is only to go higher yet clear sound volume. The room is small now but moving to very big one soon. However, if +3db is only what I'm going to gain then I would not go with this route.
ski2xblack
ski2xblack
Yep, for a measly 3 db gain you must double the power. For a significant increase, about twice as loud subjectively, it takes 10 times the power. That is more power than your speakers can handle, and why I mentioned it in your other thread. 'Loud' takes specific considerations, starting with speakers that can actually get loud without going to pieces.
slipperybidness
slipperybidness
Even a +3db gain with bi-amping is questionable. Remember, these amp channels will still be pulling power from a common power supply and that will be the limiting factor.
Now "only a 3dB gain"? A 3dB gain = double the power. That is why crossed said in his post that you would need an amp at least 350W (to double the power of the Yammy and get a 3dB gain). dB is a log scale.
You can hear a 3dB gain without question, even though it doesn't sound like a lot. What the average person perceives as "louder" though, requires more than +3dB.
As mentioned, biamping with a receiver is pretty much a waste of time. If you truly need more power, and you don't even know that yet, get an amp.
U
uaeproz
I'm gonna wait for the receiver to come. I'll test it and let you know.
Out of curiosity, anyone has a list if those amplifiers??
slipperybidness
slipperybidness
I think you are confused. Any pair of amps could be used to bi-amp, as you use 1 channel for the highs and 1 channel for the lows.
You won't even get 3 db, only an unmeasurable fraction of a db. The power divide is in the region of 400 Hz, there is very little power going though the high pass filter, almost all the power goes though the low pass filter.
Hi Experts,
Channel: 9.2
DSP Programs: 23
Dolby TrueHD: Yes
A.R.T. Wedge: Yes
MHL Support: Yes
Phono Input: Yes
Preout: 11.2-ch
DC-Diaphragm: Yes
Impedance: 6 Ohms
Cheers
Abdulla
Do you have a subwoofer? If not, get one and then use the Yamaha 3030 preouts with a Emotiva XPA-2 or a 2 channel proamp from Crown Audio and you are good to go. You may hear a difference but most likely not especially with a decent subwoofer in the mix. Those speakers are rated 50W nominal so the 3030 is already a good match for them as others have commented already. For louder and higher quality sound you need to look on the speakers side of the equation.
