I finally purchaced an AVR!!
V
ventwood0
Yes, it is true. I just went out to circuit city today and purchaced the ONKYO TX- SR504 today. I usally spend hrs upon hrs doing research before I make a purchace, but I guess I was just tired and picked this one since it was on sale for 290.00 USD. After tax it was over 300.00. Do you think this is a good buy? As most of you know already. I am certain that I will be purchacing the BIC Acoustech speakers for 799.99 very very soon. And I still have 30 days left before my return policy ends for my AVR.
Here is my AVR that I purchaced
http://www.circuitcity.com/ssm/Customer-reviews-for-Onkyo-Home-Theater-Receiver-TX-SR504/sem/rpsm/oid/148422/rpem/ccd/productDetailReview.do#tabs
The speakers I will be getting
http://www.acousticsounddesign.com/core/view_BigProduct.cfm?pid=1061&sc=32&t=226
Guiria
Guiria
If you must by locally then it's probably fine. I just bought the Yamaha HTR-5960 (compare to the audioholics review for the RX-V659) from an authorized internet dealer for 330 shipped. The yammie has pretty good reviews from audioreview, avsforums, and here at audioholics. Just my two cents.
V
ventwood0
I posted this question in a few other forums, do you think I should take this guys
advice?
In response to you last question "NO". The 816 is a good receiver but so is the 504. They are comparable feature/price wise, you wouldn't be gaining anything. I've got a budget Onkyo on one system and a budget Pioneer on the other and I prefer the Onkyo but that's just me. Objectivly they are compairable.
Seth=L
Seth=L
Consider this, the Pioneer has auto set up, and it has preouts on all channels. The auto set up makes things incredibly simple, and preouts allow you to upgrade to a better amplifier in the future without replacing the entire receiver. If it were me I would go with the Pioneer, because I have a seperate amp, both will have nearly the same power so the difference audible won't be much.
hyghwayman
hyghwayman
Pioneer VSX-816
ventwood0 said:
Well, my rooom is basically a rectagnle, and with just a narror walkway leading out of it. It is the perfect home theater room in my opinion....... but the auto setup does look appealing.
What about this AVR?
http://deal.ritebuys.com/viewitem.php?IndexID=35321&RefTag=froogle
I have had this model for about two months and am very pleased, the sound is clean and the set-up is simple. Only thing missing on the Pioneer is the up-conversion from composite to s-video. But I don't need that feature anymore.
One more word on the Auto Sound Set-Up, It is not persice but very close to it (beter then by ear) It is preferable to use an SPL meter (C-weighing, Fast Response) for greater accuracy.
http://www.audioholics.com/techtips/setup/loudspeakers/settingspeakerlevelsdistan.php
Seth=L
Seth=L
The Yamaha has some nice features, that is for sure.
Sheep
Sheep
Wafflesomd is trying to sell his 816. Take your receiver back, and buy his. Help a member out, get a good price, anbd get a better recevier.
If you're interested PM me, I'll notify him that you want it (doesn't hang around much anymore).
SheepStar.
