Thank you for the input. Clearly, I am a novice in this area. Can you give me any more info on the "Direct" function? Where, how, etc. Also, is an equaliser commonly built into an AVR, or is it an ancillary component?
Regards, Danem
I don't see where you told us what AVR you have.  It would help.
"Direct" is another playback mode, like Stereo, or Dolby or All Channel Stereo.  It likely has its own button on your remote.  "Direct" bypasses/defeats most of the audio enhancements done by your AVR.  It essentially passes the AVR input directly to the AVR output.
Do you remember the "Loudness" button on the old receivers?  To my ears, today's Stereo or Dolby settings are like putting the Loudness on.  "Direct" is like turning the Loudness off.  Audio is a bit cleaner, but more subdued, especially at low volumes.
Usually when listening to music, I'll use "Stereo" at lower volumes, "Direct" at higher volumes.  For TV/Movies, the Dolby settings provide a fuller sound, especially the surrounds and subwoofers.  "Direct" tends to soften the surrounds and subs, and provide a cleaner center speaker.  And since voices come from the the center speaker, "Direct" may help you.
