Humming form main speakers ...Please help
  • Thread starter dannynguyen3573
  • Start date
dannynguyen3573
I have an humming come in form front speakers when i turn it loud wiht out playing any thing. Please help why is that happen. Thanks
Jason Coleman
It may be your receiver...what type is it and what kind of speakers are they?
Jason
joelincoln
Possibly a loose connection somewhere in your system...
dannynguyen3573
It's adcom preamplifieds and PSB speakers. Thanks
dannynguyen3573
I being check all connection and clean them with chemical already.
Jason Coleman
Hmmm...sounds like ground loop hum. Try disconnecting equipment and see if you can isolate the source of the hum. Cable is often the culprit, as it is often grounded in tandem with the electrical panel.
Jason
