htr5890 overheating at high volume
8-track
8-track
my yamaha htr5890 is overheating and going into saftey mode when playing music cd's at about -5 db. Nothing is stacked on it and it has room to breathe. It does not do this with dvd's or multi channel sacd. Did anyone ever have this problem? and am I just playing it too loud?
Buckeyefan 1
Buckeyefan 1
Yes, others have had this problem. You aren't playing it too loud if that's how you like to listen to music. Here's a few questions that may resolve the issue.
What mfg/model of speakers do you have (are they 4 ohm/what spl)? How many do you play with cd's? IE 2, 5, or all 7.1?
Does your entertainment center have a glass front, or solid rear?
Are your speaker wires terminated well? No stray wire strands?
Is the top of the 5890 hot to the touch? If so, make sure the back of the cabinet/entertainment center is open, and consider hooking up a pc fan over (or blowing across) the heat sink of the receiver. You can splice a cheap pc fan to a cheap voltage converter (the kind on small electronics/cordless phones to convert 120v to ~12v or less). Then simply plug the fan into your switched outlet on the receiver so it turns on with the unit. I'd recommend a quiet fan from Radio Shack.
http://www.directron.com/quietfans.html
8-track
8-track
I'm really just getting started with all the technical stuff and don't have the lingo down yet. I have 5.1 bose speakers which I'm looking to upgrade but are stuck with them for a while. I know their compatible 4-8 ohm don't know what "spl" is and play mostly reg. cd's on 7ch. stereo altough I only have 5. There is no front glass where the amp is but there is a back to it, I thought that as long it could vent through the top the back or sides shoould not matter. I believe my wires are not a problem but not sure? If you could explain to me how the speaker wires could cause it to overheat, I always thought if something was wrong with the wire all that would happen is distorted or no sound to that speaker. Thanks for the help looking at fans
Z
zumbo
Open the back. :)
rschleicher
So-called 7-channel or 5-channel "stereo" is probably the hardest mode on a receiver, since you are sending identical signals to multiple speakers. The left stereo channel goes to the front left, the left surround, and (if equipped) the left back surround, the right stereo channel goes to its 2-3 speakers, and then a mono-mix goes to the center channel. This is harder on the speakers than most discrete 5.1 source material, where the surround channels are more or less uncorrelated to the front and center channels, and also tend to be at lower power levels. Since the transient peaks (in 7-ch stereo mode) occur in multiple channels simultaneously, you are also more likely to overtax the receiver's power-supply, which may not be capable of delivering full rated power to all channels simultaneously, when they are highly correlated.
You might want to try sticking to straight 2-channel stereo, or else using something like PLII (or PLIIx) for derived 5.1 or 7.1 playback from a 2-channel source. Although 7-channel stereo fills the room with sound, it also is a pretty artificial effect, at least in my opinion.
highboard
htr5890 overheat
I have also had the same overheating problem. Running: Yamaha HTR5890 w/ Kilpsch speakers: Sub-12, F-3, C-2, S-2. Reciever is setting on counter with plenty of ventilation. Fed from a Phillips 5 -disc cd/dvd player (from an older HTS). overheated numerous times playing CD music.
Would an external amp help this? what would be the correct way to hook up?
I do like the reciever, but cannot live with the overheating. Ran in 7-stereo mode due to sound quality.
