Hmmm, I see. While I have somebody here who has a HTPC hocked into a receiver, mind if I ask a few questions that have been bugging me?
Firstly, with the digital audio connection to the receiver, does that work even if you playing things like mp3s, etc? I notice on my PC there is an option to only send AC3 audio from DVDs out the S/PDIF port or I can send everything over S/PDIF using something called 'PCM'. If you are sending Mp3s, WAV files, etc does the receiver convert them into some kind of 'emulated' surround sound, or do they just come out of the front two speakers?
Also have you got your HTPC's video out connected into the receiver using DVI/HDMI, or does it go directly to your TV? Do you think it is important to get a receiver that can take DVI/HDMI input? I notice its only the higher end ones that seem to have it.
Thanks for your help! I think I'm finally starting to get the 'big picture'
