After experimenting every which way
with the Yamaha A-S700’s impedance selector
and a variety of different loudspeakers, every
one of which I knew the exact impedance of
(thanks to graphs of the impedance modulus-
es, and lists of the actual measured ‘nominal’
overall impedance supplied by
Newport Test
Labs
), I eventually concluded that if you are
using just a single pair of speakers with the
A-S700, you should set the impedance selec-
tor to the ‘high’ position, even if the label on
the rear of the speaker says ‘4Ω’. It is only if
you have connected TWO pairs of speakers to
the A-S700, and will be using the A+B mode
regularly that I would recommend using the
‘Low’ position. (I know this is somewhat at
odds with Yamaha’s recommendation, but I
think Yamaha is playing it super-safe.) As a
result of my investigations, all my listening
sessions were conducted with the A-S700’s
impedance switch set to the ‘High’ position.
