Nice review of the Hsu speaker. It seems like an interesting speaker, especially at this price point, to get this level of performance and aesthetics.
There seems to be a problem with consistency because there is no universal formula for determining performance. Clearly performance should be determined from Treble Extension through Dynamic Range on the list. On the HSU if we just average those numbers we get 4, whereas the performance was rated as a 4.5. On the SVS if you average those same numbers you get 4.42 which is basically 4.5 (taking out soundstage that wasn't in common with both). If you leave in soundstage you get 4.5. So the SVS speaker was calculated with just a simple average of the performance attributes, whereas the Hsu speaker review was not.
I'm fine with not using a simple average of the performance attributes to arrive at the performance score, if Gene or others prefer to weight categories differently, but it would be nice if there was consistency across the website so that you can compare one speaker to the next. Otherwise the scores lose much of their meaning.
Now there is a difficulty comparing performance of a $500 to that of a $5000 speaker, because most reviewers are not likely to score treble extension on an absolute scale. Otherwise manufactures for $500 speakers are no longer likely to send their products for review, if they get 2/5 on this and many other performance attributes. Then Audioholics would gradually only being reviewing more and more expensive speakers as time goes one. I think that this is where value can help us figure things out. Here we are trying to determine how this speaker compares to others in their pricerange in performance and aesthetics, where again performance is relative to price. That is a really tough thing to judge, especially if the reviewer doesn't have a lot of reviews under their belts. So they can just try their best. Also the person reading the review needs to take some responsibility. They first will likely look at the score to see if they are interested in reading the review at all. If they are interested then they have to dig in to find the subtleties missed by just looking at the scores. Often in the conclusion reviewers will give some details of how the speaker being reviewed compares to others in the price range, which helps more in understanding how the value number was arrived at.
Also, I think soundstage is a good attribute that should come back in future reviews. It is something that is important and not accounted for in any of the other attributes.
