What color wires do you have.
Usually (but not always) yellow is +12v constant, red is +12v switched, and black is common ground.
Note that +12v consstant NEEDS to go to an ALWAYS ON +12v source, while +12v switched goes to a +12 source that turns off when the car's ignition switch is in the "off" position.
Blue is remote (antenna or amplifier)
The rest should be speaker connections, stripe is usually negative. Just hook up a cheapo driver to each speaker pair and figure out which channel it is using the balance and fader.
