how would i get this impedance
craig7
so, i have two subwoofers, the sony and the panasonic. i wanna hook both up to my amp but i dont wanna blow it and i want the most power from it. my problem: the sony is 3ohms the panasonic is 4. the lowest impedance the amp does is 2ohms. how can i wire this without damaging my amp or subs?
Its impossible. You need two amps. You can't parallel them and if you series them there will be a power imbalance. There would be a power imbalance even if you could parallel them.
To use one amp the speakers must be identical. You need two amps.
