How to run speaker wire?!!
Joseman37
Hi there.
This might be a dumb question, but how does one run a speaker wire on a wall (not inside it. I don't want to break my wall).
Thank you.
William Lemmerhirt
William Lemmerhirt
Also search cable raceways....a variety of things you can do.
WaynePflughaupt
WaynePflughaupt
Here’s a good option:
If you do use a cable chase, my advice from personal experience is to NOT use the adhesive backing. If you ever go to remove it that adhesive backing will remain stuck to the wall, and it’ll be a major chore to get it off, if you can at all. It’s better to simply screw them down. Small screw holes can easily be patched and painted.
Regards,
Wayne A. Pflughaupt
Ponzio
Ponzio
Regards,
Wayne A. Pflughaupt
Cool.
I'm hoping to modify my office/listening room this year and this is a great option, instead of drilling/fishing my speaker wires and it's 16 gauge to boot.
Did you paint yours? Just wondering how it blends in.
WaynePflughaupt
WaynePflughaupt
I've never used it. I've always been fortunate enough to be able to run my wire in-wall.
Regards,
Wayne A. Pflughaupt
