How to mount B&W CM1 speakers from ceiling?
DDBear
I will be getting B&W CM1 speakers, but because of room architectural constraints I must mount them hanging from the ceiling.
Does anyone manufacture a mount for CM1 that would allow me to do this nicely without having to drill holes in the top of the speaker? I suppose I can use a generic speaker mount but I am trying to avoid messing up the wood in case I ever have to change location in the future.
DDBear
Well so far I found the B-Tech BT77 but that is for wall mounting. I suppose I can modify the BT77 by adding a vertical column to the wall plate, so it can hang from the ceiling beam. Then I'd need to find a nice looking vertical beam with a top plate to complete the J shape. hmmm
MidnightSensi2
Have you considered just buying some speakers with flyware?
Danley Sound Labs
JTR (he'd do flyware I bet)
Like a Danley SH100.
DANLEY | SYNERGY HORN
