Y yonyz Audioholic Jun 19, 2008 230 0 28 Oct 22, 2018 #1 Hi, How can I measure the performance of a diy sub? Mostly low end extension and distortion. I should mention that the sub is in a room, how will that affect the results? Thanks.
everettT Audioholic Spartan Apr 7, 2016 5,695 0 113 61 Oct 22, 2018 #2 yonyz said: Hi, How can I measure the performance of a diy sub? Mostly low end extension and distortion. I should mention that the sub is in a room, how will that affect the results? Thanks. Click to expand... First you need to invest in a measurement mic like the umik1 or umm6 and freeware like REW. From there you can do in room or outdoor ground plane measurements. Depending on what you want to do, we can point you in the right direction to start.
Y yonyz Audioholic Jun 19, 2008 230 0 28 Nov 7, 2018 #3 everettT said: First you need to invest in a measurement mic like the umik1 or umm6 and freeware like REW. From there you can do in room or outdoor ground plane measurements. Depending on what you want to do, we can point you in the right direction to start. Click to expand... I have acquired a UMIK-1. I’d like to do in room measurement.
S shadyJ Speaker of the House Staff member Oct 16, 2006 12,053 0 113 Nov 7, 2018 #4 You can try a close mic measurement. Place the mic a few inches away from the driver and run a sweep. That isn't a perfect measurement, there are caveats there, but it is a start, and it can give you an idea of the response. Here is some background on the technique. Hopefully your sub isn't ported.
