How to find a 12v trigger cable???
Davemcc
Davemcc
ADK,
I downloaded your operating manual and I see exactly the situation you're in. It would be nice if the trigger had an "all" selection, but it only has zone 1,2,3,off. Also, if I'm reading your post correctly, when you select MR&S in rear surround mode, it switches the rear surround speaker posts to zone 2, but at the same time, it also switches the RCA rear surround preouts to zone 2.
I can think of only three ways of compensating for this, but none are perfect. It's tough. Maybe somebody else will see this and have much more intelligent comments to add.
Option 1. Run the trigger from zone 1 and always run zone 1 whenever you need zone 2, just keep the zone 1 volume at zero. This is probably what you already do.
Option 2. Since there is not really any 6.1 programming material, use the MR&S surround setting and run zone 2 from the receiver's rear surround speaker post. Split the RCA signal from a surround output with a Y adapter and feed it to both the surround and rear surround channel of the 7.1 amp. This way all 6 zone 1 speakers are run off the main amp and zone two doesn't need to have the amp on at all. But there's devils running all over the details of this as well. It would be easier to set up if you have gain control for each channel on the amp and if you picked up one more RX-4 to split both surround channels to run 7.1.
Option 3. Run the 6.1 from the regular preouts to the amp in zone 1. Get another 2 channel amp and run it from the MR&S outputs. Assign the 7ch amp to zone 1 trigger and the 2ch amp to the zone two trigger.
One caveat also. Check with others before you take any advice from me. As I said earlier in this thread, "Lots of things don't work out for me", but it's not for lack of trying.
adk highlander
adk highlander
Sith Lord
Dave,
Thanks for all the effort. I have been running round and round with this. What I am actually doing now using the signal selection on the amp and turned of the trigger functions. The MPS-1 has a toggle switch to have on, signal, trigger. I have it set to signal so when the amps senses audio it clicks on. The main drawback is that if the volume is low the amp may not respond until you turn it up far enough and worse during a movie at low volumes a channel may switch off.
So for now this is still the best way. I just saw Emotiva is running a sale if I could afford it now I would just grab the matching 2-channel for my system. Oh well. Thanks again.
Davemcc
Davemcc
Here's an update. I just picked up my 12v trigger cable. Yes, it took me this long to order and recieve a simple 1/8" mono to 1/8" mono cable. That's life here in Soviet Canuckistan. On the bright side, it works perfectly.
ParadigmDawg
ParadigmDawg
Now to put a spin on this thing; can I take a cable like this and cut off one end to makes it work with the Emotiva?
Davemcc
Davemcc
Yeah, so much for standard connectivity. I don't see why some units use bare wire connections for the trigger. Still, whatever the connection type, it is a nice feature to have when you need it.
ParadigmDawg
ParadigmDawg
I have never cut of the plug on a cable like this but I assume it just has a couple of wires in it?
adk highlander
adk highlander
Sith Lord
Greg,
Yes, there will be two wires inside or possible one in the center and the other wrapped around it. If it is the latter than the center wire is the pos and the outer is the neg. If it has two side by side they are usually color coded red (+) and black (-).
Did you get your amp already?
ParadigmDawg
ParadigmDawg
Thanks!
Heck no; they still dont have them in.
Greg,
