Brian,
The above posts have told you all you need to know in order to connect 2 vcr's to each other and dub your tapes.
It sounds like you don't understand electronics at all, and better have a friend come over and do it for you. I know you private mailed me, but I can't say it any plainer than above. I am assuming that your VCR's have "Screw Connections with a needle in the center" otherwise known as coaxial cable or coax for short, and the connector is called an F-connector. Connect the "cable out" coax connection of the first VCR to the "Cable in" coax connection of the second VCR. Then Connect the "cable out" coax connection of the second VCR to the coax connection on the tv. Make sure the tv is on channel 3 or 4, whichever one the VCR's use, and push play on the first VCR, and record on the second VCR, and you should be able to see on the TV, what the second VCR is recording. If there is a "TV/VCR" button on the remote of the 2nd VCR, make sure it is on VCR. That way you see the feed from the VCR.
Anyways, good luck.
Mark
PS: Chill out, and don't demand help. You will get more of it by being less obnoxious.
