How to do manual eq for pioneer vsx- lx 302 -7.2 channel net work av receiver
Dr.Vinayaka.G
Good morning sir
My home theatre area-room- 17'6'' X 12'00'' with wooden flooring
System config:
One Pair Wharfedale Diamond 230 Floorstanding Speakers
One Piece Wharfedale 220 Centre Channel Speake
Two Pair Wharfedale 10.DFS rear/Surround Speakers
Wharfedale D-10 Subwoofer
One pair of warfaedale 10. DFS as height speakers
Pioneer LX-302 Av Receiver
I am not getting good surround effect.
I configured speakers by Macc tuning and speakers are in perfect alignment
I sincerely seek help regarding suggestions for improving sound quality I am not getting punching bass when watching movies even on Blu-ray Disc. Please advice me regarding procedure of manual eq.which frequency should I choose and how many decibels I should keep for all Speakers. Please help.
With regards
Vinayaka
Have you tried turning up the subwoofer level in the avr?
You may or may not do better with manual eq but no one can really tell you how to set it over the internet for your room and speakers. It's about experimentation to see if you can get a result you like. If you want to increase bass, start with the lowest frequency options on the eq settings.
Dr.Vinayaka.G
Subwoofer - I tried increasing volume and it only gives booming effect. In auto macc- it is giving all speakers 0.5 to 1 to 1.5 decibels for all speakers some are on negative side also.
In manual eq should I increase bass for all frequency? How do I know which frequency gives the best effect
