Hi. I'm newbee, not audiophile-- can you help?
I want satellite+sub for HT and am trying understand what satellite I need for my space. We watch TV within 5800cuft room, TV along long wall, sit about 15ft wide space, 8-10ft from TV. Question: Does room size matter or speaker placement for sizing satellites?
For Sub you size for full volume of the room.
For satellites mainly interested direct sound (?) so I would think placement (distance to speaker) should matter, not room size to first order. Is this correct?
I see 2-way bookshelf speakers, w/5 1/4-6 1/2" woofer, MTM advertised "suitable for large rooms" on websites. Same people's 2-way MT w/same tweeter do not say this. Both MT and MTM have higher decible level and continuous power vs. my present speakers (Advent Legacy II). My present speakers can play loud with 8Ohm 80-100W/channel amp and reach low (<=40-45Hz?). Example= Ascend Acoustic CBM 170SE rated @ 8Ohm, 91db, 200W continuous pwr; CBM 340SE rated @ 8Ohm, 92db, 240W.
Is there other specification, equation for selecting speaker impedence/ power/db level needed to play loud satellite+sub HT? Is the comment mentioned, e.g. Ascend Acoustic MTM being "suitable for large rooms" not relevant when you add a sub? I have a constrained budget and am looking at budget MT with 5-6" woofer like Ascend 170SE, Hsu HB-1, etc, don't want to pay for MTM like Ascend 340SE unless I need to to play loud.
Thanks!
tman
