I'd second Rickster's suggestion. A good 70 volt mono system would work very well in this case, especially if you have outlying areas with speakers, and no need of stereo reproduction (which in most distributed sound systems would not be a good idea anyway).
Of course with a 70 volt system you would need speakers that have variable tap settings, so that you can adjust the wattage based on how many speakers you have running in parallel with the amp, also as a factor of the amp's power output. Not sure if these speakers are capable - most that I've seen are variable in certain increments and also have selections for standard 8 ohm setups.
EDIT: Nevermind, I should have followed Rick's link before posting the above - looks like a very informative web page on 70 volt systems, and also illustrates how to use an external line matching transformer to acheive the same thing as what I mentioned above.
