Specs for power output and power consumption will vary depending upon
which reference U are looking at:
USA website
Euro website
Operation manual
Service manual
Rear panel
These specs are largely driven by the destination market...
Note that the USA/Canada AVR market share is about 50%, Euro AVR market share is about 30% and the rest of the world makes up the rest.  Note that for power consumption this is changing significantly as CE(standard for Europe) is tightening up on power consumption disclosures especially in the stand-by mode.  This is where the Eco-Mode feature came from, and the brand doesn't want too many versions sold world-wide so they try to standarize for most efficient production,  while satisfying their biggest markets and respective
unique safety standards..  In Europe, CE requires an AVR to turn OFF after 4 hours if no input signal is seen. This is where the Eco-mode came from, plus they are requiring
 lower and lower power consumption when in the stand-by mode.  Europe is way ahead of North America for becoming
more green, even their internal carton packings are now bio-degradable rather than the harder styrofoam end-caps that doesn't break down well in the landfills.
Regarding power output specs..
Check the following:
Yamaha AV Euro site for RX-A2080
https://europe.yamaha.com/en/products/audio_visual/av_receivers_amps/rx-a2080/specs.html#product-tabs
Rated Power Output(1kHz, 1ch driven): 220W(4 ohms, 0.9%THD)
Yamaha AV USA site for RX-A2080
https://usa.yamaha.com/products/audio_visual/av_receivers_amps/rx-a2080_u/specs.html#product-tabs
Rated Power Output(1kHz, 2ch driven): 155W(8 ohms, 0.9%THD)
So here U can see the Euro version has a
higher, publishable power output spec..
Bottom line..
The more advanced, larger markets each have their
own unique safety approval standards which are changing while smaller markets lag behind in changing their specification and approval standards.   It is not meant to be more confusing, but presently these safety standards are undergoing certain local updates.
Just my $0.02...
