Im a bit of a noob at home theatre so i wanted to know how much u guys would pay for a Fleetwood 5.1 Home theatre speaker system, 6100 series with onboard amplifier.
Total System*
Frequency response- 35Hz~22K Hz
Impedance- 4~6 ohm
Power Rating- 100 watt RMS
200 watt program material
80 watts/ch for front+rear
100 watts for centre chanel
Sub Woofer*
Frequency response- 35Hz~200 Hz 90 dB / W-m
Impedance- 6 ohm
Power Rating- 100 watts RMS
Component- 10"6 ohm Woofer in a ported out viny1 wrap cabinet
Crossover- 35Hz~150Hz adjustable
Built in amp- 100watts RMS Amp, inverse phase selector, Hi/Low inputs, Volume control 115V/230V Dual Voltage, Auto power on/off
Front+Rear channel*
Frequency response- 95Hz~22 K Hz, 88dB / W-m
Impedance- 4 ohm
Power Rating- 400 watts RMS
Component- Shielded 4" woofer & 1/2" Dome tweeter in an ABS enclosure
Crossover- 6dB / Oct2-way
Centre Channel*
Frequency Response- 86Hz~22K Hz, 90 dB / W-m
Impedance- 4 ohm
Power Rating- 500 watts RMS
Component- Dual Shielded 4" woofer & a shielded 1/2" Dome tweeter in an ABS enclosure
Crossover- 6 dB / Oct2-way
So anyone with any sort of an idea of how much this is worth please help out!
Cheers.
