IF all else is equal (it usually isn’t) more xmax = more displacement of air
More air displacement = More SPL
If you have the same Sd, assuming the motor is up to the task the driver with more Xmax will be louder.
33mm vs 22mm xmax is a 50% increase in movement. Theoretically the one with 33mm can play louder.
Lots of variables though so the answer is not always so simple.
