How do I minimize projector noise?
  • Thread starter Thread starter mark_wininger
mark_wininger
5
0
0
I just installed an Infocus 4805 projector on the ceiling directly above the viewing couch.
It gives a good picture on the low power lamp setting, with barely detectable cooling fan noise.
It gives a BETTER picture on the higher lamp setting, but the fan is MUCH noiser.
I called Infocus and was told there was no adjustment for a lower fan speed on the higher lamp setting.
Has anyone had success in reducing fan noise?
Can I cut an internal wire to the high speed circiut of the fan, withiut burning out the lamp and electronics?
Can I build a vented box out of noise reducing foam/ material? (where do you get the foam/ material?
Does some company sell a noise reducing enclosure?
Please let me know of your suggestions or experiences.
Thanks, Mark
Thanks for the info. Sorry for the double post; I was concerned it might not get read or a reply in the other section.
Mark
