<font color='#000000'>I have a Denon AVR 1600
(http://www.usa.denon.com/catalog/pdfs/avr1600.pdf) and am trying to get it to recognise the digital inputs. I have one connection coming in from my cable box and the other from my DVD. It recognizes the analog inputs, but not the digital inputs.
I can't find the manual and can't seem to find a PDF of it online. Anyone have any advice?
I found the blurb below on Denon's website but it doesn't give
specifics for the AVR 1600.
Thanks in advance!
--John
8) THE FRONT PANEL INPUT CHOICES ON MY DENON DOLBY DIGITAL RECEIVER OR PREAMP/PROCESSOR DON'T SEEM TO MATCH THE REAR PANEL CONNECTOR ID'S. FOR EXAMPLE, MY FRONT PANEL SELECTORS SAY "CD", "VDP/DVD", ETC. WHILE
THE REAR PANEL HAS INPUTS LIKE "AC-3 RF", "COAXIAL", AND "OPTICAL". I'M CONFUSED. HELP!
Although it might seem a bit confusing at first, this difference
actually makes your Denon easier to use in the long run. Think of it this way -- the front panel selectors tell you what source component you want to enjoy. The real panel inputs are simply different pipelines to get the sound from a particular source component to your Denon's internal processing circuits as effortlessly as possible.
Because many source components give you a choice of how to do this (analog or digital outputs from an LD player for example) and because very few of us hook up a complex home entertainment system in quite the same way, Denon gives you a lot of flexibility without confusing a more casual user (your spouse, your kids, . . . or maybe even you!) with a bewildering array of choices.
The trick here is knowing that you can "program" your Denon so that it knows, for example, to choose the "Coaxial" rear panel input when you push the front panel "VDP/DVD" input selector.
Before you make any of these changes, however, remember that your Denon has already been preprogrammed with certain "default" connections. Don't worry as these can easily be changed but it's nice to know where you're starting from before you begin to customize things, isn't it?
The AVR-5600, for example, has the following default selection already made:
If you press this front panel input selector . . . . . . . . . you get
CD Coaxial (digital)
TV/DBS Optical 1 (digital)
VDP/DVD Optical 2 (digital)
Tape 1 Optical 3 (digital)
You can change these default selections easily by following the instructions in your Owner's Manual. And you'll need to do this if you want to use the rear panel coaxial (digital) jack to receive the audio signal from a new DVD player.
Remember that you only need to do this once. After that, you can just enjoy one-touch convenience regardless of the source you're using.
That's the real benefit of the flexibility built into every Denon
surround sound component.</font>
