Hey guys,
Ok, now I purchased this equalizer (Kenwood KE-205) and decided not to use it on my system. Should I return it ($50) or should I connect it up to the subwoofer to tighten up some bass? The sub is pretty tight now, but I am not sure if an EQ would make it sound any better. The only thing is..the frequency ranges on the EQ are as follows...60 Hz, 150 Hz, 400 Hz, 1 kHz, 2.4 kHz, 6 kHz, and 15 kHz. I think for a sub, the low frequencies on the EQ might be a little high for the sub, however instead of boosting 60 hz and below, maybe it would sound even better if I could cut some of the frequencies above 60 hz. Just curious what you guys think. Thanks for your help!
