How can i blow up my SUB?
I have a 200watt H/K sub that i am getting tired with, i can get a new one only if my H/K sub is not working somehow. that's the deal i have with my parents. the sub already has a flapping noise coming from it, also when i play it for like 10 mins or more i can smell something burning from the back of the sub. this sub is nothing special its for my second HT in my room. so as a replacement i wont be spending to much money. i have tried many different things to destroy it, nothing seems to work.
thanks
Go out into the country and put a 12ga to it:D
GlocksRock
GlocksRock
Why not just take the driver out, and snip the tinsel leads, that way it won't work for sure.
lsiberian
lsiberian
like do u mean go lower then 20hz or above at like 30hz,
this is really pissing me off. i did it for another 2 hours today, it would heat up and turn off for like a min or so and then would turn on itself.
I doubt you have enough amp to blow the driver. Also there is probably a filter built into the sub. If you want to really blow the sub you will need to surge in a lot of power.
I
mnnc
If it's that difficult to blow up then why not keep it.:confused:
