hooking up a bathroom into home theater setup.
adk highlander
adk highlander
Sith Lord
I was also amazed at how fancy Craig's system was. I'll never get that fancy, though...so I'm not even going to try! :D
Three glasses of cheap wine down the hatch, btw. The holiday is a startin' early.
Warning Thread highjack:
Thanks guys. Believe me it took me a while to get there.:rolleyes:
Oh cheap wine. Red or white? I can drink cheap Red but can't do the whites. Happy Turkey Day Guys.
Adam
Adam
Threadjack continues...
Red. It was Manischewitz Concord Grape. Mmmm, so sweet. All gone now. Probably time to try to calm the buzz, as it's only 6pm. :)
I agree; cheap white wine is difficult to get down.
L
lizardloren
Another new one that looks nice is the [URL="http://www.universalremote.com/product_detail.php?model=136" said:
URC KP-900[/URL] It can be done without adding any wire if you add a base station. So instead of the MSU you would need a RF base stationbase station and flashers like I lised above.
That looks very nice but a bit out of my price range, and a bit much for just audio. I was looking at something like this:
Will this allow me to seek FM stations? And there is another version that is IR. Is that just the same thing but being able to use a remote with it? AND I notice that the IR flasher goes on the IR window of the AVR. If I do that can I sill control the AVR viva my remote in my living room?
When my whole A/V project is over its box wine for me. ;)
adk highlander
adk highlander
Sith Lord
That model is only compatible with their multizone receivers and is not useable in the configuration you are setting up.
Yes I have several on my sources that are shared between the theater and the whole house system and I am able to control them just fine.
L
lizardloren
Hey thanks, but does anyone know of a keypad that would work for my system. I have been looking for 2 hours and all I seem to find are keypads that go along with there system. I like the looks of that niles I listed above, but at this point I would be lucky to find any.
L
lizardloren
Hey guys, If anyone is wondering I have decided to go with the KP-900 wireless keypad with the MRF-260 bass station. I have bought 2 Definitive UIW 94/A in celling speakers. I will use my iPhone to control the apple tv. Bought some speaker cable from blue jeans: 350 in total:eek: for the bathroom and my living room. Got the definitive Pro monitor 1000 for my front and surround, Center is a Definitive C/L/R 2002 and a Pro Sub 800. I got some in wall plates for some nice looking speaker wire which I will make viva this guide, which is very nice, cheek it out: http://www.audiokarma.org/forums/showthread.php?t=94203.
Thanks so much for your help! Could not have done it without you guys!
PS. I will alway dream of having a system like Craig's. Good work!
adk highlander
adk highlander
Sith Lord
I think that will be a great setup. I was not able to find a good alternative for you either. Its weird sometimes the older intellipads are easy to find and then they are gone. That is a new model and the keypad layout looks great.
Post pics when you are done. That will be a very slick system.
