Hometheater in a box? which one to order?
pans
i'm a newbie and doesn't have any idea on how to setup and which hometheater system is good. I am wondering among these two following which one is the best. If not are there any other HT system that comes in a box with in a range of 400 to $700.
1. Klipsch HD 300 Compact 5.1 High Definition Theater system
Model
Brand Klipsch
Model HD Theater 300
YAMAHA 5.1-Channel Digital Home Theater Receiver RX-V367 newegg
2. YAMAHA 5.1-Channel Digital Home Theater Receiver RX-V367
2 nd:
# 1. YAMAHA RX-V667BL 7.2-Channel Receiver
Polk Audio RM75 High Performance 5 Piece Surround System newegg
2. Polk Audio RM75 High Performance 5 Piece Surround System
I've started to shop around and cme across these. Realy appreciate any other inputs
Cheers,
lsiberian
lsiberian
pans
great thank you. your reply gave me some idea. will do some more reading on this forum.
dTor
With your budget, an inexpensive component system is definitely doable. A great website to check out for great deals on darn near anything is www.slickdeals.net.
