sheep- i thought ratings were for output power, and that the power can be translated to sound because the power translates to work done by moving the column of air (ie sub movement) so therefore more power=more air moved=stronger waves=louder... but if car amps are rated at power used not supplied than a 60% efficient amp at 1000W would only be supplying 600W...
haoleb- basically what i want to replace my blown home sub and i have a car sub sitting around that i thought i could use if i powered it, and im trying to figure out home amp or car amp via voltage conversion or just buy a new home sub altogether...
markw- i was thinking of old ham radio equipment and computer power supplies, get enough so that when the amp peaks its only about 60-70% of max power for the 12V lines, i didnt think it'd be too hard to get 100-110 amps from about 5-6 of these supplies, and theyre about 20-30 each, totals 100-180, compared with 3-500 for a dedicated home converter that could output 100A...
Seth - i figured that might be the case too, and i tried testing how loud the subs would be in an enclosed space about the size of the room where i want to put the sub (20x25), the garage. Now im not sure how much noise is lost by the car but it seemed to me the home sub i had was as loud if not louder than the car setup. yes, i had the trunk open, but i still had the box in the trunk, if that makes a difference...
basically im trying to decide if i should go jerry-rig a car system or just buy a home sub. I dont really want to spend more than 250 on this but i want to feel the movies/music when its up all the way. So i was trying to do a little research as to why car audio is rated so much more powerful than its home counterparts, but i guess its because people think more power= more sound, and so totally irrelevant?
