Hi all! I have just purchased a set of Klipsch speakers.
Rp 250f
Rp 450c
Rp 240s
R 10sw
Now l’m looking for an AVR with 7.2 channel and Dolby X and Atmos .
I planing on getting rp 140s upfiring atmos add on later so will be running 5.1.2.
I like the Denon x- 3400h avr, would this be a good choice for these speakers? Also getting a Sony A1 65” Oled TV and a oppo 203 4K player.
Really want some in put on different AVR units.
My HT room size is about 4m W and 5.5m D.
Thanks in advance
Eyes24
Can you attach speakers to the ceiling? The Klipsch upfiring speakers work much better than some of the other designs due to their controlled dispersion, but upfiring speakers suck compared to overhead speakers.
You don’t have to cut holes in the ceiling. I have a pair of Klipsch rb 10s mounted to the ceiling using an omnimount. Works very well.
Also, if possible, I’d return the Klipsch sub and get something else, outside of their r 115sw, their current offerings aren’t great for the price. You could get a hsu vtf 1 for that price.
As for an atmos receiver, it really just depends on your budget and what you want out of it. Outside of features, their are only two things that matter with receivers, channel count, and amplifier power. All solid state amps sound identical unless pushed into distortion.
How big is your room and how far away do you sit? At 10’ away, you will have no problem listening at Reference volume with 100w. Generally people listen at about -10dB from Reference, which would still only require a measly 13wpc.
Considering you’re using Klipsch speakers, unless your room is enormous, you won’t need that much power.
