Home Theater System recommendation?
justinisfilming
justinisfilming
So our current home theater system broke a few weeks ago and we're trying to find a new one. We got to see some pretty decent Samsung and Bose ones over at Best Buy but I'm just wondering, for a budget of about $800, which one would you recommend? I'm looking for a speaker system by the way.
P.S. Even though I said $800, the cheaper the better. If there is something really good for $500, then we'd prefer that. :D
ImcLoud
ImcLoud
So under $800 for speakers, sub and receiver or just speakers and sub? How big is the room?
this is the cheapest system I would recommend, most likely will be better than anything you can buy for $800 from bose...
Dayton Audio SUB-1200 12" 120 Watt Powered Subwoofer 300-629
DENON AVR-1513 5.1ch Home Theater Receiver 3D ready | Accessories4less
1 of these Newegg.com - Pioneer SP-C21 Center Channel Speaker Each
2 pairs of these- Newegg.com - Pioneer SP-BS21-LR Bookshelf Loudspeakers Pair
that will put you around $400 and be a really good sounding system, if you want to you can try buying 3 centers and using them for your front 3 instead of the bookshelfs....
If you really want to spend the entire $800 and have a good sized room,
Buy 2 of them subs $220
step up to the new pioneer andrew jones speakers $400 with towers
and get that same denon $130
That will be around $750
For cheap, buy the Pioneer speaker system. Go to Best But and check them out.
miniSQ
How does an entire home theater system break?
And what are you classifying as a "speaker system"?
What is going to be powering this system?
