Hi - I have a 20x25 family room in the basement. I am planning on buying some equipment for 2 different purposes and wondering if you can give me some tips. My biggest question is if a single set of equipment will be able to cater both needs
Need 1: Surrond sound system for a 50 inch TV (quality of music is important as well as the effect and base)
Need 2: Dj Speakers - should be able to have higher volume and considerable amount of base. Also should be able to play for about 2-3 hours continuously.
Can I get away with one set of equipment? (one speakers, one speaker system)
I will not be using the equipment for parties all the time. maybe 3-4 times an year - that's it. But will be mostly using it for Home Theater. So if there is a package that you can suggest which can be used primarily for Home Theater, but can be extended if needed for some basic Djing (I will buy the mixter, cd set separate) - that will be great. Also for DJing, I am not looking for a whole lot of base with a whole lot of power (volume)
My budget is around $1000-1500 for Home theater speakers, amp/receiver (if both needs can be accomodated in one set of equipment, I will spend closer to 1500+). I would like to stick with good brands like anyone else
thanks!!
