Home Theater Calibration
N
ninja12
I was a little bored last night so I decided to calibrate my home theater system which is 5.1. I have a Yamaha RX-V2500 receiver which has the YPAO. The first round of calibrations I used the YPAO to calibrate, and I did a few minor adjustments like setting all my speakers to "Small" and a little fine tuning for the speaker levels using my Sound Pressure Level (SPL). I set my receiver's volume to 0 db and then I set my speaker levels to 80db using the SPL. I noticed that using the white noise from the receiver the volume for each speaker was extremely high in order to reach the 80db. I talking +8.5 and +9.0. So I decided to use the Sound Vision Home Theater Tune-Up disc to set my speaker levels. Once again with my receiver's volume set to 0db, I set my speaker levels to 80db. However, I noticed using the white noise from the disc that I had to really lower each speaker's volume. Now I'm talking -4.5 and -6.0 to reach 80db.
After saying all that, I am wondering which one should I use to set the volume for my speakers. Should I use the white noise from the receiver or should I use the disc. I guess what really matters is that all the speakers are reading the same db.
Please let me know what you think.
MDS
The difference you notice is due to the level of the test tones. The internal test tones are at -30 dB. If you calibrated so that the meter reads 80 dB you are actually a little higher than Dolby Reference Level.
If the channel trims didn't have to be set so high with the HT tune up disc, I would assume it uses a level of -20 dB. If you use that tone and calibrate so that the meter reads 80 dB, you would be slightly lower than Dolby Reference Level.
