Home made power amps
Bryceo
Bryceo
Found some videos on YouTube of home made power amps that seem to work any one else seen anything like it or done it them selves?
ImcLoud
ImcLoud
I built one of the parts express class d kits, not really much to do, plug in p-supply and mount in chassis.. cheap, I gave it to my brother who used in with an avr that had a damaged amp section, not sure if he still has it...
Bryceo
Bryceo
How did it go? I'm thinking of attempting it my self
slipperybidness
slipperybidness
I haven't had a chance to check out your posted vids yet, but I'll take a look.
What were you thinking? One of the chip-amps or hypex modules?
I just completed a Dyncao ST-70 tube-amp kit that is awesome, but tubes.
Take a look at these, if a kit is an option:
This is a full kit: Akitika GT-101
These don't include heatsink, chasis, or P/S: Power Amp Kits by AmpsLab
ImcLoud
ImcLoud
It worked but I messed up the board a little trying to mount it in the chassis, nothing that changed performance {I don't think}, but I had to glue it a little, shaquad... This was really easy, not like the kits where you have to do a lot of soldering, not that that is hard, but more labor than plugging in a power supply and mounting it in a chassis with some banana posts...
slipperybidness
slipperybidness
I like the whole shebang of a bag of parts and 30 hrs of work to get a nice piece of gear. More difficult, takes more skill, nice product, but a real chance for a big mistake. You can certainly build equal performance with better parts than a commercial amp, for less $.
Also, you learn a lot along the way. And when the day comes that something malfunctions, I will have no problems popping the cover and finding the problem. Or, if I ever feel like upgrading electrical components, then I can do it. It isn't for everyone.
Bryceo
Bryceo
That's the idear behiend my sudden intrest
jcl
I was thinking about building an amp from parts from parts express. However, I'm not sure it makes economic sense for the high powered class D route (as opposed to tubes.) If you look at PE amp specs they tout a watts/channel but if you look at the details it's into 2 or 4 ohms with 10% THD!
Like this $90 - '2x300' TAS5630 Class-D Amplifier Board, specs are Power output (w/ 50 VDC power supply): 300W x 2 (4 ohms, THD 10%), 160W x 2 (8 ohms, THD 10%), 240W x 2 (4 ohms, THD 1%)[h=1][/h]http://www.parts-express.com/pe/showdetl.cfm?partnumber=320-309
Or the $99.99 1x600 w/ch one which in the details is a 10% thd spec into 2 ohms, the 8 ohm spec is 1x200 with .4 thd.
Two of those plus a power supply is over $300, for which you can get a crown xls drivecore 1000, which will do 550 w/ch into 2 ohms, 215 w/ch into 8.
slipperybidness
slipperybidness
Like this $90 - '2x300' TAS5630 Class-D Amplifier Board, specs are Power output (w/ 50 VDC power supply): 300W x 2 (4 ohms, THD 10%), 160W x 2 (8 ohms, THD 10%), 240W x 2 (4 ohms, THD 1%)http://www.parts-express.com/pe/showdetl.cfm?partnumber=320-309
Personally, I don't think I would be doing any class D builds anyway, but you make a pretty good point.
I was thinking more along the lines of A or A/B (and of course tubes).
