In looking through some of the stuff over on CA, I came across a really interesting thing.
Jon Risch made the statement that WBT now has a 75 ohm RCA connector...
Wow...so I looked at it..
Part number WBT-0110.
It is a wideband plug for digital and analog connections...
Now, it seems that an apology is needed...
In response to an article written here, Jon put on AR, a "scathing" diatribe, slamming Gene and the AH crew for such errors...
Here is the archive link...
http://archive.audioreview.com/03/0EF9530A.php
It takes a huge amount of time to download, the archives there are terrible..
I copied the relevant parts...Jon's ERRORS are colored in red to show all...
Gene's article excerpts are green..and one of my posts in the thread is colored blue...
Needless to say, it was a 7 part rebuttal..so I didn't copy it all...but everybody can find it if they wish...
re: Critique of Video Cable Tech Article, Part 2 (this is by JR)
SEC 2.3
[ Mismatched impedance is one of the most common and most frequently experienced sources of signal degradation. This phenomenon occurs when a 75-ohm signal encounters different impedances through its signal path, usually on the order of 35-ohm or 50-ohm for Home Theater applications. It can occur in video cables that do not use true 75-ohm RCA connectors, .... ]
Well, that would be great, except that there is no such thing as a true 75 ohm RCA phono connector! More on this later, in response to section 3.5
Whoa! This would be funny if it weren't stated in an entirely serious manner. Apparently, the writer has swallowed some manufacturer's hype about "true 75 ohm RCA plugs", which is ironic given that the avowed purpose of the article is to provide solid information about video cables, rather than to parrot what has been hyped.
Bottom line: no matter what the RCA plug itself is doing, the female RCA jack is not 75 ohms impedance. Period. End of discussion.
Even if, by some miracle, the RCA plug itself could be made to be a 'true' 75 ohm impedance, which I am not convinced that it can be (nor are quite a few knowledgeable RF folks and engineers), then it would still be a moot point since the RCA female jack is not a 75 ohms Z.
Yes, the RCA plug on the right will be slightly worse than the one on the left, as it does have a "constriction" in the overall diameter of the barrel to center pin, as shown. This is not necessarily a show stopper, or a huge problem. After all, as we have seen earlier, the plug shown as being of a 75 ohm impedance, has an impedance discontinuity due tothe differing diameter of the inner barrel where it is cut out for access to the center pin.
So these RCA plug related impedance discontinuities are more a matter of dgree, rather than any sort of absolute.
[ That being the case, only a few component video cables actually have true 75-ohm RCA connectors since very few exist. ]
In point of fact, no real 75 ohm impedance RCA plugs exist. Much has been made of a certain brand of plugs that do everything they can to promote this myth, but if the claims and wording of this brand of plug is examined closely, one will find that words and phraseing like "75 ohm coaxial cable compatible", or "impedance-matched" or they make reference to a VSWR measurement, but they really never come out and SAY that the plugs are actually endowed with a 75 ohm impedance, nor do they mention if the plugs were measured for VSWR when actually plugged into a female RCA jack!
So it should be clear at this point, that it is not possible for an RCA plug to acheive a true 75 ohms impedance.
Now, further down the thread, I describe very clearly, how it is indeed possible to make a true 75 ohm RCA connector set...
Hi Jon jneutron
Jan 14, 2003 11:57 AM Thanks for the analysis, Jon. The .33 is the diff from Bruce, he estimated .25.
Spiral was proposed to meet existing equipment form factor, and to allow non keying operation. And nothing prevents the female from spiralling in the other direction. If the two spirals contact in more than one point, the impedance is certainly of concern. But, arranging the spirals to only cover 180 degrees on each part can guarantee only one point contact.
And, if instead of spiralling wires, use a flat ribbon on each, with correct geometry for the dielectric type of course, and now you have to key the new type to guarantee alignment of the ribbon contact, with the keying mechanism not affecting the compatability in any direction. Compatable keys are easy to design to allow old and new to be completely interchangeable.
It is definitely possible.
Cool..I like the technical conversations.
Cheers and thanks, John
First and foremost.......where's that retraction from Jon Risch??? He was so confident...wasn't he?
Second...I detailed exactly how to make one, and if you look at the time stamp, all can see that I, Johnny Escadillo, laid the foundation for this 75 ohm rca plug on January 14,2003 at 11:57 AM....(not sure what time zone that is, of course...)
Third...once a patentable design is part of the public record, it can no longer be patented as a world patent...this is what I have to deal with in my work environment....a paper or presentation, once given, voids worldwide patents..
Fourth...a USA patent can be applied for, within a year of entry into the public record......and I believe, only by the person who entered it into the public record....dat be me...(but, I am not 100% sure of that point, the lawyers here seem to kinda waffle on that)
Fifth...once an idea has been in the public domain for one year, it cannot be validly patented...
Can anyone tell me when the 75 ohm rca was patented by WBT??? I tried their site, and was only able to find the patent covering the clamping mechanism, not the mods for 75 ohm...
If they filed after Jan 14, 2004....then their claim is invalid..and they will be unable to defend their right to the connector....meaning anyone can build them without restriction...It would have been so much easier just asking me....I woulda been happy to assign rights, for perhaps a nickel or dime a connector....If they filed within the specified timeframe, then they have to provide proof that they came up with the idea BEFORE I made it public record...
Geeze, it ain't about the money....but manufacturers who choose to take an idea from a forum, and run with it....gotta be smarter..
Course, if they filed before Jan 14, 2003....then I have a severe case of egg on face...
Unfortunatly, I've ben unable to find a patent on the 75 ohm...any help out there??
And the REAL LESSON here????? It is quite clear that Jon was in error on that point...painfully so...and yet, he blasted another, quite a few times.. Granted, HE was unable at the time, to imagine a solution to the problem, but I did...and, WBT did..
Doesn't mean he's always wrong..but, how many people believed what he said??
Is an apology warranted from RISCH? Nah...although he stated absolutes, really all he was stating was that he could not do it...
Hey, we are all right at times, wrong at times...it's the attitude that we will be remembered for..
Cheers, John
