I doubt that the setup your using with those wires right now would result in excessively high capacitance. A couple known designs with high capacitance are the Cat5 speaker cables and some kimber designs. Both of which use quite a bit more conductors than what your using.
Just to be sure maybe you can take your set of cables to your buddys place and see if you notice any difference on his system with those cables.
