This thing works FANTASTIC!!!! The only thing wrong with it is the directions
1. Would help if they have on there that you have to charge one of the batteries prior to it working.
2. Picture of exactly how the rechargeable battery goes into the sleeve (which end goes where) and how the overall deal goes into the AA sleeve.
3. Better explaination of the "stick on eye".
Anyway, this thing worked just like everyone said. I had two AA batteries in my universal remote (the remote that came with my digital comcast box) and took one out one of the AA batteries and replaced it with the battery that was supplied (but don't forget to charge it first and it takes about 12 hours to charge) and bang...worked right out of the box.
The cool thing about the package is that it comes with two of the rechargeable batteries. So, while you are using one, the other is being charged in the bottom of the little saucer deal.
Also, if you have more than one one remote that you what to add to the extender all you have to do is get another battery insert and it will add on to the existing one you have!
AUTiger,
The "stick on eye" is exactly what you need (it comes with the package). It has a cord attached to it and you plug it into the saucer deal. You can then stick it on the front of your TV or somewhere in front. The stick on deal is about the size of your pinky fingernail if not a little smaller.
The cord that is attached to it seems to be about 6-8 feet long.
Anyway, this thing is exactly what I was looking for and thanks to everyone that helped.
