Hi my name is jimi and i am an Audioholic
jimi
I'm trying to set up surround sound is it best to run long speaker cable to the surrounds or have a amplifier near the surrounds using short speaker cable and long rca's to the amp coming from preamp ''Lexicon CP2'' ?
Jeff R.
I would run the long speaker cable. It is much less expensive than the RCA cable.....it should make no difference in performance either way.
fuzz092888
fuzz092888
+1
Get some speaker cable from monoprice or a place like it and you'll be fine and it will pretty cheap, much cheaper than the other option you mentioned.
Welcome to the community:)
How long is long?
collegeaudio
14awg minimum for that length, 12awg to be safe.
Safe from what ?
Safe from more voltage drop across the wire length:D
As a good practice, you want the total resistance of the wire in both direction to be less than 5% of the speaker impedance and best to assume 4 Ohms as even 8 Ohm speakers can dip into the 4 Ohm range. 14 ga is just below that with .18 Ohms.
