here is the ones i like
brandan
brandan
i went to best buy and when i heard the
Vienna Acoustics 6" Floorstanding Speaker
that is what made me want new speakers so i was also like to know if the m22 sound about the same that is the sound i am looking for and can you guys recommend any that sound about the same and dont cost so much
No, the M22 does not sound the same.
What exactly is your budget and what are you trying to achieve? Music, movies, both?
brandan
brandan
both and i would like to stay about 450 for the pair
markw
Listen to everything in your range but concentrate on music when auditioning.
Almost everything sounds good on movies but it doesn't work the other way around.
You might look for a NHT dealer and go listen to the Classic 3 a listen ($399 at Audioadvisor.com). Also a B&W dealer, give the 600 series a listen. These are both likely a bit brighter than the Viennas, but they might work for you.
Online, the AV123 Ref .5 might fit the bill too. Plus they have the risk free trial with them.
jcPanny
jcPanny
Av123
The AV123 X-series has a couple models of inexpensive floorstanders, the X-sls and X-mtm. In the real wood veneer they will probably look as good as Vienna Acoustics but probably wont sound quite as good.
I have the higher end Onix Reference 1's. The look and sound great and sell for about $500/pair used. Audioholics is also working on a higher end bookshelf shootout including Ascend, RBH, and others.
