tritondelmar
I have Denon avr-2309ci and sony blu ray playerbdp-bx1 ,and I can't get dts HD master audio and Dolby tru HD,decoding from de receiver,I'm using only hdmi cables and I allready set up blu ray player, and receiver as owners manual suggest,any advice? Tanks
Adam
Adam
Welcome to the forum!
I don't know the answer, but I wanted to bump this so that maybe someone who can answer it sees your question.
I have seen the same question around here before, so I'd suggest doing a search on this forum while you're waiting for a better answer here.
Adam
jliedeka
jliedeka
I'm not familiar with either your receiver or Blu Ray player but I can make an educated guess. Your receiver should adapt to whatever it is getting over HDMI so it's probably not a receiver setting. I would look through the audio menu on your Blu Ray player and make sure it is bitstreaming all Dolby and DTS codecs. Maybe the manual can help with this.
You may also need to specifically choose those audio tracks when you play a disc by going into the audio setup for the disc.
Jim
jostenmeat
Jim, I believe in fact you are familiar with his player. I think its the same as yours, but with a different model number for Costco.
tritondelmar, make sure to actually select TrueHD or DTSMA from the disc's menu as well. Some blurays default to the lossless codec, and some don't.
Some don't have any lossless codec at all, because I don't think "uncompressed PCM" is technically considered a codec.
tritondelmar
Jim
Jim is true.My blu ray player BDP-BX1 is the same Sony You have ,I got it at COSCO ,it have an internal Dolby Tru HD decoder,I set it up HDMI (AUTO)
tritondelmar
Tanks Audiophyte,The Denon Receiver AVR-2309ci Is New Model,I got 'cause has 4 HDMI inputs,And Dolby Tru HD and dts HD Master Audio,and I replace my old Denon AVR-3600 ,acording to the owners manual,when the HD sound is decode the little indicador ligth,on the receiver must to turn ON,just I got multichannel sound input on the display .And of course I always select the Hd sounds on the blu ray disc menu,Tanks Gabriel
tritondelmar
Could You,tell Me how You got set up Your audio on Your blu ray player?
jostenmeat
Ok, try setting it to "bitstream" to see the logo. IIRC, I think your player can only bitstream DTS-MA anyways, and if I'm right about that, you want to bitstream then in any case.
Should be in the audio menu, which is probably very easy to access. Please report. :)
tritondelmar
Tanks jostenmeat,I GOT AT LAST!!!!! I enter on system set up,then to HDMI control then set ON,And presto My receiver is Decoding Hd Sound ,Tanks to the forum and You guys,
jostenmeat
On behalf of weez guyz, I'd like to say you are quite welcome. :D
