Tomd51, it appears both of your suggested options would require drilling some holes into these speakers. If so, how would I best go about doing that? Also, if you follow your 2nd link, there is another mount near the bottom that is like a platform speaker mount. It is kind of like a shelf. What do you think of that option?
I thought about shelves, and may go with that option.
I currently have stands, and am purposefully taking them out of the equation. I have two little ones who consitently bump into them, ocasionally knocking the speakers off. The mounts or shelves will be high enough to eliminate the dangers of kids on sugar.
