Thank You Adam Plus more Info
Adam, Thank you for the link. Silly me, could have Googled it! However, my set up still doesn't work. It's either the splicing of wires I had to do to lengthen some of them them or I have something plugged in incorrectly. Here's a little more info:
I have 3 different sets of speakers and they all fall in the 8-16 impedance req'd for the receiver.
I have a new 42" 1080p AOC Envision LCD HDTV L42H861 connected to coaxial cable, JVC Receiver (as mentioned before), Bose 123, Pioneer PDM423 Multi-Play CD Player and an Admiral VHS 4-Head Video Cassette Recorder Mod. 20419. I want to listen to the radio and CD's via the receiver and the speakers, also the TV audio and the DVD player thru the same.
I had it all working before I moved them to the new entertainment center I got for the new TV. I labeled all the wires, drew a diagram where they all went and then got the "bright" idea to use the Speaker Selector I never got around to using. I spent last night and all today buying more wire, stripping wires, splicing them for more length and after reading the link you sent, I connected 1 speaker to a terminal on the receiver then to a amp/recvr terminal on the spkr slctr. Nothing! So I added the other speaker in the pair but again, nada. Other than going back to the old set up sans selector, I don't know what to do.
Any ideas or suggestions? Anyone? Thanks again!!!
