Help with receiver/amplifier selection?
K
Kirk Warner
Hi all, first let me say, I know this is not the best equipment out there and that I wasn’t looking for that kind of system. I have a 6 room office that I am trying to distribute music through for employees and customers.
I am installing the Pyle 6-room In-ceiling Speaker System’ – model number KTHSP125 audio distribution system.
I am installing the speakers in six different locations/rooms in my office, using a combination of stereo/mono configurations depending on the size of the room.
Each set or single speaker have their own in-wall impedance matching vertical slide volume control, model number – PVC2 back to your, ‘six channel high power stereo speaker selector - model number PSS6.
Question: I was wondering if you could advise me on an AM/FM/CD stereo receiver/amplifier would work best with this setup. I would like to stay under $300.00 if possible but not limited too.
Here are some spec. on the speakers and selector:
Speakers:
5.25-inch midbass speaker
1-inch high temperature voice coil
Directable 1-inch polymer dome tweeter
150 watts rated peak power
Frequency response: 80Hz-20K Hz
4-8 Ohm impedance
Selector
Channel high power stereo speaker selector
Up to four separate speaker pairs to your stereo system
Accepts speaker wires up to 14-gauge
Handles 100 watts per channel
Protection circuitry keeps it running smoothly
Frequency response: 20Hz-20KHz
Thank you, any help would be much appreciated.
Kirk Warner
shadyJ
Speaker of the House
Staff member
You will need multi-room amplifiers like these. You will not want an typical AVR, they will not be able to do what you need.
K
Kirk Warner
Thanks for the reply and so sorry for the delay... been out of town. I went to the page suggested but I'm afraid I'm a bit out of my element. Any suggestions as to which pre amplifier with AM/FM tuners you would recommend that will have enough power to support the 7 to 8 speakers I am installing?
